You can use PlotXY to plot a single point on the ScatterGraph. There are two overloads of the PlotXY method - one that takes two double[] array parameters and one that takes two double parameters. So far you have been using the first one to plot arrays of X/Y values. The other overload takes a single X/Y value pair and should do what you're looking for.
To draw a line from one X value to another in a straight line, you can use the PlotXY method that you've been using, but make the Y values in the Y array the same. For example, to draw a straight line from X coordinate 0 to X coordinate 10 at Y Coordinate 5, you could do this:
double[] xValues = new double[] { 0, 10 };
double[] yValues = new double[] { 5, 5 };
graph.PlotXY(xValues, yValues);
- Elto
n
