error 2920 while installing setup application using cw3dGraph
I created an installer through Visual Studios setup and deployment tool (VS2008). I use Measurement Studio 8.6.  I included CW3dGraph_OCX.msm (8.0.0), However when I run the installer I recieve the following error message.
"The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2920."
I have seen similiar posts but they talks about version 7.0 and datasocket MSM's. But I don't use any this things
How can I resolve this issue?
(3,637 Views)
Hi 3aychoucha,
Here is a similar discussion post.
http://forums.ni.com/t5/LabWindows-CVI/Installer-Error-2920/m-p/1178701?requireLogin=False
Make sure that you look in the help and make sure that you have the all the required msms included in the installer.
Thanks!
Chris T.
(3,617 Views)
