error handling with VB.NET 2005
I am pretty new to .NET and I am trying to write an error handling loop to make sure my reads and writes to my instruments  are ok.
Does anyone have some examples of code on how to do this?
Here is a copy of the read function I am creating:
Public Function Read(ByVal strInstrument As String) As String
        Dim strRead As String
        Dim strerr As String
        Try
            mbSession = CType(ResourceManager.GetLocalManager().Open(strInstrument), MessageBasedSession)
            strRead = mbSession.ReadString()
        Catch exp As Exception
            strerr = exp.ToString
            MessageBox.Show(exp.Message & strInstrument, "GPIB READ ERROR")
        End Try
        mbSession.Dispose()
        Return (strRead)
End Function
Thanks in advance,
Michael
(3,767 Views)
Mike,
When you install the NI-VISA driver, examples are installed by default to C:\Documents and Settings\All Users\Documents\National Instruments\NI-VISA\Examples .  I was able to find a SimpleReadWrite example in the DotNET3.5\SimpleReadWrite\VB folder that shows how to read/write and handle errors properly.  The code you posted looks good...is it able to run properly?
Eric B.
(3,748 Views)
