gaugedouble range binding
i've a Problem by Setting the Range of an GaugeDouble with MVVM
Here is my Code that doesn't work. Hope anyboy can help me:
 <ni:GaugeDouble  Range="{Binding GaugeRange}"  Value="{Binding Value}" Width="auto" />
and in my Viewmodel
 private Range<double> _GaugeRange;
         public Range<double> GaugeRange
             get { return _GaugeRange; }
             set
                 _GaugeRange = value;
                 NotifyPropertyChanged("GaugeRange");
 Thanks for your help
Message 1 of 9
(8,185 Views)
There is a known issue with how the numeric scale synchronizes its range with the numeric control when it is initialized. Instead of assigning Range only after it has been edited interactively, it will assign it when the scale is initialized, overriding the binding.
Instead, you will need to use a two-way binding:
    <ni:GaugeDouble Range="{Binding GaugeRange, Mode=TwoWay}" ... />
~ Paul H
Message 2 of 9
(8,177 Views)
Hi Paul,
thanks for your Answer.
I tried the Two-Way Binding but it doesnt work!
I have
GaugeRange = new Range<double>(-900,900);
Is that ok ?
What else can i try ?
Message 3 of 9
(8,170 Views)
Here is the complete example I used to test the two-way binding:
    Code
    using NationalInstruments.Controls;
    using System;
    using System.ComponentModel;
    using System.Windows;
    namespace GaugeRangeBinding {
        public class Model : INotifyPropertyChanged {
            private Range<double> _GaugeRange = new Range<double>( -1.0, 1.0 );
            public Range<double> GaugeRange {
                set {
                    NotifyPropertyChanged( "GaugeRange" );
            public event PropertyChangedEventHandler PropertyChanged;
            private void NotifyPropertyChanged( string propertyName ) {
                var handler = this.PropertyChanged;
                if( handler != null )
                    handler( this, new PropertyChangedEventArgs( propertyName ) );
        public partial class MainWindow : Window {
            public MainWindow( ) {
                InitializeComponent( );
            private void OnMouseUp( object sender, EventArgs e ) {
                var model = (Model)textBox.DataContext;
                var range = model.GaugeRange;
                model.GaugeRange = new Range<double>( range.Minimum, 2 * range.Maximum );
                textBox.Text = model.GaugeRange.ToString( );
    XAML
    <Window x:Class="GaugeRangeBinding.MainWindow"
            xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
            xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
            xmlns:ni="http://schemas.ni.com/controls/2009/xaml/presentation"
            xmlns:local="clr-namespace:GaugeRangeBinding"
            Title="MainWindow" Height="300" Width="400">
        <Grid>
            <Grid.DataContext>
                <local:Model />
            </Grid.DataContext>
            <ni:GaugeDouble Range="{Binding GaugeRange, Mode=TwoWay}" />
            <TextBlock x:Name="textBox" MouseLeftButtonUp="OnMouseUp" />
        </Grid>
    </Window>
The XAML contains a text block that covers the screen, and clicking the text block causes the OnMouseUp handler to change the range on the model, which updated the gauge via the binding.
~ Paul H
Message 4 of 9
(8,162 Views)
Hello Paul,
thanks for your Answer. Your Example works fine. but in my Case it isn't working.
I've got the GaugeDouble in an DataTemplate
<DataTemplate x:Key="Gauge">
                    <Grid ContextMenu="{StaticResource cmenu}">
                        <Grid.RowDefinitions>
                            <RowDefinition Height="30" />
                            <RowDefinition Height="*" />
                        </Grid.RowDefinitions>
                        <Label Grid.Row="0" Content="{Binding Title}" Padding="6,6,0,0" Background="#A0B2FF" BorderBrush="White" BorderThickness="1" FontSize="14"></Label>
                        <Border BorderBrush="white" Background="Gainsboro" Grid.Row="1" BorderThickness="1,0,1,1" Width="200"
                                        Height="200">
                            <ni:GaugeDouble  Range="{Binding GaugeRange, Mode=TwoWay}"  Value="{Binding Value}" Width="auto" />
                        </Border>
                    </Grid>
    </DataTemplate>
 The DataTemplate is Used in an ItemsControl. That doesn't work. All other Controls where working fine.
What can be the Issue ?
Message 5 of 9
(8,147 Views)
Here is my complete Solution:
XAML:
        <ItemsControl Grid.Column="0" Grid.ColumnSpan="3" AllowDrop="True"   ItemsSource="{Binding Objects}"  Background="Transparent"
                       x:Name="DesigningCanvas"
            <ItemsControl.ItemsPanel>
                <ItemsPanelTemplate>
                    <Canvas />
                </ItemsPanelTemplate>
            </ItemsControl.ItemsPanel>
            <ItemsControl.ItemContainerStyle>
                <Style >
                    <Setter Property="Canvas.Left" Value="{Binding X,Mode=TwoWay}"/>
                    <Setter Property="Canvas.Top" Value="{Binding Y,Mode=TwoWay}"/>
                </Style>
            </ItemsControl.ItemContainerStyle>
            <ItemsControl.ItemTemplate>
                <DataTemplate>
                    <Grid>
                                        Height="200">
                            <my:GaugeDouble  Range="{Binding GaugeRange, Mode=TwoWay}"  Value="{Binding Value}" Width="auto" />
                        </Border>
                    </Grid>
                </DataTemplate>
            </ItemsControl.ItemTemplate>
        </ItemsControl>
    </Grid>
 The Model:
        private ObservableCollection<CanvasObject> _Objects;
        public ObservableCollection<CanvasObject> Objects
            get { return _Objects; }
            set
                _Objects = value;
                NotifyPropertyChanged("Objects");
        public Model()
            Objects = new ObservableCollection<CanvasObject>();
            Objects.Add(new CanvasObject
                Height = 200,
                Width = 200,
                X = 100,
                Y = 100
        private void NotifyPropertyChanged(string propertyName)
            if (handler != null)
                handler(this, new PropertyChangedEventArgs(propertyName));
 And here my Object:
 public class CanvasObject : INotifyPropertyChanged
        public CanvasObject()
        private string _Name;
        public string Name
            get { return _Name; }
            set
                _Name = value;
                Title = _Name;
                NotifyPropertyChanged("Name");
        private string _Title;
        public string Title
            get { return _Title; }
            set
                _Title = value;
                NotifyPropertyChanged("Title");
        private object _Value;
        public object Value
            get { return _Value; }
            set
                _Value = value;
                NotifyPropertyChanged("Value");
        private double _Width;
        public double Width
            get { return _Width; }
            set
                _Width = value;
                NotifyPropertyChanged("Width");
        private double _Height;
        public double Height
            get { return _Height; }
            set
                _Height = value;
                NotifyPropertyChanged("Height");
        private Range<double> _GaugeRange = new Range<double>(50, 900);
            set
        private double _X;
        public double X
            get { return _X; }
            set
                _X = value;
                NotifyPropertyChanged("X");
        private double _Y;
        public double Y
            get { return _Y; }
            set
                _Y = value;
                NotifyPropertyChanged("Y");
        #region PropertyChanged Event Implementation
        private void NotifyPropertyChanged(string propertyname)
            if (PropertyChanged != null)
                PropertyChanged(this, new PropertyChangedEventArgs(propertyname));
        #endregion
 The Binding of the Range-Property doesn't work in this case. But why ?
Message 6 of 9
(8,146 Views)
Accepted by topic author manuelhoedl
With your full code, I was able to reproduce the issue. I am not sure why the binding is being cleared on a control inside a data template, as opposed to the behavior outside.
As a workaround, I have found you can use a binding on a custom attached property that assigns the range directly:
    XAML
    <ni:GaugeDouble my:Extensions.Range="{Binding GaugeRange}" />
    Code
    public static class Extensions {
        public static readonly DependencyProperty RangeProperty =
            DependencyProperty.RegisterAttached(
                "Range", typeof( Range<double> ), typeof( Extensions ),
                new PropertyMetadata( OnRangeChanged ) );
        public static Range<double> GetRange( DependencyObject d ) {
            return (Range<double>)d.GetValue( RangeProperty );
        public static void SetRange( DependencyObject d, Range<double> value ) {
            d.SetValue( RangeProperty, value );
        private static void OnRangeChanged( DependencyObject d, DependencyPropertyChangedEventArgs e ) {
            var pointer = (NumericPointer<double, double>)d;
            pointer.Range = (Range<double>)e.NewValue;
~ Paul H
Message 7 of 9
(8,137 Views)
It works perfect Smiley Very Happy
Thank you very much 🙂
Message 8 of 9
(8,132 Views)
Just wanted to let you know the Range binding issue was fixed in the Measurement Studio 2015 release, and no longer needs the TwoWay mode workaround.
~ Paul H
Message 9 of 9
(6,560 Views)
