hi, I’m developing a program in c# which uses the NI 9233 for acquire my signal but I can´t process my data
hi, I’m developing a program in c# which uses the NI 9233 for acquire my signal, after that with the two arrays from my data acquisition, I try to use the CurveFit method, right now I have my two arrays fully populated and this line code:
fittedArray=CurveFit.PolynomialFit(xArray,dataArray,nOrder,PolynomialFitAlgorithm.Svd);
And my catch message is:
The type initializer for ‘NationalInstruments.Analisys.Math.CurveFit’ threw an exception
(3,234 Views)
Choque,
Thanks for contacting National Instruments!
What exception are you getting?  I took the liberty of throwing together a quick example for you in C# in which I calculate a Polynomial Fit and then plot it on a graph.  I think that if you take a look at how I've done it in this quick example you should be able to tailor it to fit your application.  Note that this example was developed with Visual Studio 2005.  Let me know if this helps!
Derrick S.
Product Manager
NI DIAdem
(3,215 Views)
