how can I add plot and a gage to NI example ContAcqVoltageSamples_IntClk_ToFile
I am new to .NET, so I tried to use the NI  ContAcqVoltageSamples_IntClk_ToFile example to get an anlog reading, display  and save. I also wanted to add a plot and gage control to display the waveform on the plot and the current reading on the gage.  But had difficulty converting the data array in the example to a format I can use for the plot and the gage.
Does anyone know of any example code to perform this task?
Thank you very much for any help.
Here is a portion of the NI example code that I am trying to add these futures
private double[,] data;
//Read the available data from the channels
                    data = analogInReader.EndReadMultiSample(ar);
                    //Plot your data here
                    //Displays data in grid and writes to file
                    DisplayData(data, ref dataTable);
                    LogData(data);
                    analogInReader.BeginReadMultiSample(Convert.ToInt32(samplesPerChannelNumeric.Value),
                        analogCallback, myTask);
(3,546 Views)
Hi ege,
You should be able to call something similar to: waveformGraph1.PlotYMulitple(data).  There is an example of plotting continuously acquired data using the Waveform graph at this link.  Also, if you go to the Measurement Studio help, and perform a search on "gauge" you will come up with an article entitled "Walkthrough: Creating a Measurement Studio Application with Windows Forms Controls and Analysis" that will walk you through using both a Waveform Graph control and a Gauge control along with example code. Hopefully this will help out!
Cheers,
Kelly R.
(3,517 Views)
