how can we convert LabView VI to DotNet C# code
(9,011 Views)
.....if you got any solution, Please post it.
(8,653 Views)
Simply re write it 🙂
 You might want to refer to this : http://zone.ni.com/devzone/cda/tut/p/id/3189
Shreyas Hebbare
Shreyas Technologies
India
(8,619 Views)
One suggestion is to use LabVIEW 2009 and the new .NET Interop Assembly option in Application Builder. This allows you to build and distribution VIs in a LabVIEW project as .NET interop assemblies. Then you can just load up these assemblies directly from your .NET application.
Just another thought.
Check out the Building a .NET Interop Assembly LabVIEW Help topic.
Best Regards,
Jonathan N.
(8,600 Views)
Another option is to build a dll and call the dll in your C# application.  It's not that tough, depending on your variables.  You create your vi, add it to a project, right-click build specifications, click new -> shared library and go from there.
Hope this helps.
B
(8,432 Views)
