how to fill the plot area partially in fill mode
a Plot vs  a base Y (=80) Plot
I just want to fill the area where the Plot Y value > 80
How to control the fill to just partially fill the plot area.
Please see att image.
Message 1 of 13
(5,688 Views)
What version of Visual Studio and Measurement Studio do you have? What language are you using?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
Message 2 of 13
(5,661 Views)
NStudio 8.1.1
Using C#
Message 3 of 13
(5,657 Views)
VS 2005
Message 4 of 13
(5,656 Views)
Hi Matt,
With a plot in Measurement Studio, you can set fill information.  In the designer, select your WaveformGraph and click "Edit Plots" in the properties window.  Select your plot, then you can modify the necessary fill properties.  To generate the picture below, I modified BaseYValue to be equal to 50 and the FillMode to Fill, keeping FillBase set to YValue.  Does this look like what you are looking for?
Eric B.
Message 5 of 13
(5,633 Views)
No.
I just want to show the area where plot's Y value > 50.
So for this example, just want to fill the area where X > 1 and X < 4
Don't want to fill the area where Y valud is less than 50.
Please check my previsou attached pig (just fill the shade area)
Message 6 of 13
(5,628 Views)
Just want to fill the shadded area.
If the dot line Y is 50, just need to show the plot's Y > 50.
Don't want to fill any if plot's Y < 50.
Message 7 of 13
(5,625 Views)
Matt,
Here is an example of exactly how to do that. It is certainly a non-trivial task, but here is a link to the example code: http://decibel.ni.com/content/docs/DOC-7483
Message 8 of 13
(5,578 Views)
How to remove the filled area?
Apparently, it is NOT able to use
waveformPlot1.FillMode = PlotFillMode.None;
Message 9 of 13
(5,431 Views)
Were you unable to get my example to work? What exactly are you trying to make not visable in the plot?
Message 10 of 13
(5,399 Views)
