insert graph into word document
I have a graph that i would like to programmatically insert into a word document.  I am using C#.  right now i have the document being populated with information about the graph but now i would like the graph to be inserted.  is there an easy way to do this?
(4,312 Views)
Hi Layzie292,
first you will have to save the control to an image, and then you can place the image in Word.  To create the image, use:
WaveformGraph1.ToFile("<path here>", ImageType.Jpep);
You should then be able to place it into the word document using:
wordDoc.InlineShapes.AddPicture("<pic path here>", ref object LinkToFile, ref object SaveWithDocument, ref object Range);
Let me know if you have any further questions!
NickB
(4,301 Views)
