is there a step-by-step guide to upgrading MS to VC++.NET
I had installed Visual Studio.NET. I then installed the MSV6 for C++.NET FDS. I copied a project from my old workstation (VC++ 6 (MS6)). I can not see any of the NI controls and am getting a compile error that \program files\national instruments\ni-imaq\lib\msvc\imaq.lib is not found. By drilling down, I see that the ni-imag subdir is not there. Is there something that I missed during the install?
Are there other common install mistakes that I need to look for?
Thanks in advance,
Chuck Bear
(4,477 Views)
Most information that you need to know can be found in the "Converting Measurement Studio for Visual C++ 6.0 Projects to a Visual C++ .NET-Compatible Format" help topic in the reference. You can find this topic by going to the Measurement Studio reference table of contents, then navigating to Visual C++ Help, Tutorials, Getting Started, Measurement Studio 6.0 for Visual C++ .NET.
You should be able to see the Measurement Studio controls in the toolbox in a Measurement Studio tab when you have the dialog editor open. If it is not there, there is a button that will reset the toolbox in the Measurement Studio preferences. Regarding the link error for imaq.lib, I think that this is because Measurement Studio does not add include/lib paths for IMAQ to Visual C++
- these paths must have either been added manually or added by another installer.
- Elton
(4,477 Views)
