magnitude / frequency Datatype VB.net
I need some help. I´m a beginner in measuerment Studio (using trial version).
I´m looking for a way to store, calculate and display datas of 2 dimensions as (Magnitude/ Frequency) or (Magnitude/Time). What is the best datatype ?
Example:
i´m reading a trace from a spectrum analyzer: I get back an Array of 500 Points (Magnitude Data)
I´m reading the start and stop frequency from the spectrum analyzer: eg start:1 GHz stop:2 GHz
1) now I want  to combine the Magnitude and Frequeny datas...how can I do that ?
2) now I want to find out the maximum Magnitude and its corresponding Frequency.
3) now I want to display the spectrum in a plot
 Thanks for any help....by the way: in agilent VEE I use the coord datatype, and the ramp function...I look for something similar in Measurement studio VB.net
(4,434 Views)
Accepted by topic author JoshxW
Hi Josh,
Try something like this
I'm assuming that you already have the magnitude, sart and stopfrequencies from the analyzer
'set a reference to the NationalInstruments.Analysis.(pro or enterprise) library
'in the property pages of your project
'then add this line to your form
Imports NationalInstruments.Analysis.Math
Public Class Form1
'add a button and scatterplot to your form
 Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim magnitude(500) As Double
Dim frequency(500) As Double
Dim bandwidth, startfrequency, stopfrequency As Double
 Dim maxvalue As Double = 0
Dim maxvaluefreq As Double = 0
Dim imaxvalue As Long = 0 Dim j As Long = 0
'get magnitude data, start and stop frequncy from signal analyzer
'with gpib or serial calls....
'for this load random dummy magnitude data
For j = 0 To 500
     magnitude(j) = Rnd()
startfrequency = 1000000000.0
stopfrequency = 2000000000.0
'calc bandwith
bandwidth = (stopfrequency - startfrequency) / 500
'load frequency data
frequency(0) = startfrequency
For j = 1 To 500
       frequency(j) = frequency(j - 1) + bandwidth
'ArrayOperation functions are part of the NI Analysis Library
maxvalue = ArrayOperation.GetMax(magnitude)
imaxvalue = ArrayOperation.GetIndexOfMax(magnitude)
maxvaluefreq = frequency(imaxvalue)
Debug.WriteLine(
"Max Value = " & maxvalue & " at " & maxvaluefreq & " Hz")
'use scatterplot1 to display data
ScatterPlot1.PlotXY(frequency, magnitude)
End Sub
End Class
Hope this helps
Curt
(4,374 Views)
Hi Curt,
yes...perfect ! it works !!!
Thanks for your help !!! *1beer4you*
Josh
(4,362 Views)
