measurement studio 8.1
Please can somebody help me with a code to with a code to read  from PCI 6023E analog channels, display the vltage reading on Textboxes and save the result to a table in MSAcess.
I recently installed Measurement studio 8.1.1 from 8.1 on my computer with using Visual Basic 2005. But whenever i call "NationalInstrument.Analysis.math, it give error "Analysis.Math" not available.
 Also there is "Application Configuration file "App.config" is invalid. Root element is missing  Error message.
Another Error messge is "Conflict between different version of the  same dependent assembly".
Yet another error is : "Erorr parsing application configuration file at line 0. XML document must have a top level element".
Any assistane to the above request will be highly appreciated. Thanks
Charlion
(4,337 Views)
Hi Charlion,
Which package of Measurement Studio 8.1.1 did you install, Standard, Professional or Enterprise?  The Standard package will not have the Analysis.Math functions available.
For the different assembly version message, you can click on the message at the bottom of Visual Studio and tell it to use the latest version.  This will update it to the latest assembly version and will remove the error.  After doing this, let me know if you also still receive the error about parsing the configuration file.
(4,316 Views)
Thanks for your prompt response. I installed the Professional Edition of measurement studio 8.1.1.
Charlion
(4,309 Views)
Hi Charlion,
I checked into this some more and the NationalInstruments.Analysis.Math namespace is only available in the Enterprise edition.  Do you know which package you had installed for the 8.1 version?
(4,295 Views)
Just as I earlier mentioned, i have Measurement Studio Proffesional Edition installed on my system. Now what is the way forward? or what alternative do i have to do some analysis using Measurement studio.
(4,278 Views)
If you are needing the Math Analysis functions, then you will need to upgrade to the Enterprise package.  You can get more information about this by calling your local Sales Representative (800-433-3488).
(4,243 Views)
