multichannel DQA
hi,
I am using MS 8.0 and VS 2005.net to build a project including two channel voltage analog in. I hope to build a task including two channels, and sample data at the same time. what can I do? Thank you very much!
YHong
(3,335 Views)
Hi YHong,
It sounds like you just need some simple DAQ examples to get you pointed in the right direction.
There are lots of examples that are automatically installed in this location
C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\DAQmx\
For sampling analog data, you will probably find the examples you are looking for in this path:
C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\DAQmx\Analog In\Measure Voltage
If you don't see the examples, then it probably means that you need to install the DAQmx drivers which you can find here:
NI-DAQmx Download
(3,325 Views)
