ni 9213 interfaced with Measurement Studio
I have a question about how to explicitly set a temperature measurement task to use High-Resolution mode for the ni-9213.  I'm able to make the measurement, but whether the measurement is made in High-Resolution or High-Speed mode is ambiguous.  I can't find an overload that let's me set it in Measurement studio using C#.
Any help would be appreciated.
Derek Hopkins
(4,916 Views)
Maybe you can set that by changing the rate and samples per chanel in the ConfigureSampleClock method
myTask.Timing.ConfigureSampleClock("", myRate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, mySamplesPerChannel)
Curt
(4,911 Views)
Hi Derek,
You will find some information about how to set the ADC Timing Mode for a NI-9213 in this document. The document states: "In text based programming languages, you will use the DAQmxSetAIADCTimingMode Property.  The documentation that explains how to use this property is in the NI-DAQmx C Reference Help.  In the NI-DAQmx C Reference Help document, select NI-DAQmx C Properties»List of Channel Properties.  The property will be located under Analog Input»General Properties»Digitizer/ADC»Timing Mode.".
I would suggest you to check the documentation in the NI-DAQmx C Reference Help document for more help as this article says.
Jorge
Certified LabVIEW Associate Developer (CLAD)
(4,892 Views)
Accepted by topic author Derek_Hopkins
C# equivalent: myTask.AIChannels.All.AdcTimingMode = AIAdcTimingMode.HighSpeed;
Brad
Brad Keryan
NI R&D
(4,881 Views)
Thanks, that is exactly what I wanted to know.
Derek Hopkins
(4,852 Views)
