nianlys and vista installation packages
Has anyone managed to successfully deploy an msi package that uses nianlys to a windows vista machine ?
I have an installer that works fine on XP but seems to always declare that it can't find this file when tried on a clean vista machine. The Merge modules I'm trying to use are :
cvirte
MSVCRT
NIMesaDLL
nianlys
mkl
nimetautils
MStudioEnterpriseAnalysis
MStudioDesign
MStudioUI
MStudioUIWinforms
MStudioCommon
Using VS2005 SP1, Measurement Studio 8.1 and also CVI 8.1 to compile a dll (hence cvirte)
The file is on the vista machine in the c:\program files\National Instruments\Analysis\Shared folder.
Any ideas ?
Paul
(3,340 Views)
  unfortunately as you can see here :
http://zone.ni.com/devzone/cda/tut/p/id/5539
, we're not currently supporting Vista with any versions of our software, although obviously we're continuing developing new versions of our products every day, and as such we've said that the neext release will support Windows Vista.
That's not to say that our current versions will not run in some capacity on Vista, however we've not partially or fully verified their behaviour so we don't support Vista issues as yet.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,319 Views)
