nidaqmx measure p-p voltage
How can I measure the peak voltage of a 75 Hz 10vp-p waveform using a nidaqmx?
(3,896 Views)
Hi Joncombat,
If you are using Measurement Studio .NET, there is an example program that installs with Measurement Studio that does Peak Detection and measures the amplitudes of those peaks.
The example programs install in one of two locations:
<Program Files>\National Instruments\MeasurementStudioVS2005\DotNET\Examples\
or
<Documents and Settings>\All Users\Documents\National Instruments\MStudioVS2005\DotNET\Examples\
And the particular example I am referring to is located under <Examples>\Analysis\PeakDetector
Hope this helps!
Jervin Justin
NI TestStand Product Manager
(3,884 Views)
I am using CVI 7.0.
Jon K.
(3,881 Views)
Also,
For more information on some of the concepts involved in the example, I would recommend the following article:
Developer Zone Tutorial: Peak Detection Using LabVIEW and Measurement Studio
Jervin Justin
(3,880 Views)
Hello Joncombat,
If you are using CVI you can refer to the forum post here, which should give you some information on peak-to-peak measurements in LabWindows/CVI.  Also if you do have questions about CVI in the future, it would be best to post them under the CVI forum so they will be answered correctly.
Message Edited by herosphro on 02-29-2008 03:21 PM
John B.
(3,873 Views)
