opcsupport.msm sometimes fails to deploy OPCDAAuto.dll during installation.
We have a deployment project in C#.NET using various NI Measurement Studio controls, including WaveformGraph, NIFgen, NIScope. It references a number of NI .msm modules, including mstudioui and mstudionet. With opcsupport.msm, on some builds we get the error, below (installation log):
MSI (s) (D8:6C): File: C:\WINNT\System32\OPCDAAuto.dll; To be installed; No patch; No existing file
MSI (s) (D8:6C): Source for file 'OPCDAAuto.dll.27EC6D16_5415_4E72_B83E_7BAA28671A7F' is compressed
InstallFiles: File: OPCDAAuto.dll, Directory: C:\WINNT\System32\, Size: 155648
MSI (s) (D8:6C): Note: 1: 2262 2: Error 3: -2147287038
DEBUG: Error 2920: Source directory not specified
for file OPCDAAuto.dll.27EC6D16_5415_4E72_B83E_7BAA28671A7F.
DEBUG: Error 2835: The control ErrorIcon was not found on dialog ErrorDialog
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2835. The arguments are: ErrorIcon, ErrorDialog,
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2920. The arguments are: OPCDAAuto.dll.27EC6D16_5415_4E72_B83E_7BAA28671A7F, ,
MSI (s) (D8:6C): Product: Demo -- The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2920. The arguments are: OPCDAAuto.dll.27EC6D16_5415_4E72_B83E_7BAA28671A7F,
The dll file is available on the build machine. When running the deployment (setup), the problem does not appear on a developm
ent machine. It also does not occur with every build; however with those builds which exhibit the problem, it is consistent. And because it leads to the termination of the installation, it is a serious problem.
Any thoughts, please?
(4,724 Views)
Hello Pete
Can you post your msi for the installer that is causing this problem? That would help us in tracking down the problem.
Bilal Durrani
NI
Bilal Durrani
NI
(4,724 Views)
