passing image from Vision.VisionImage to CWIMAQControls.CWIMAQImage
Hi folks,
I took over a project and found that image is passed through bmp file on HDD which at high res and frame rate can slow the application on older hardware. After brief look I found that image classes from aquisition Vision.VisionImage and display CWIMAQControls.CWIMAQImage classes are not directly compatible.
Each class has ImageToArray and ArrayToImage functions and it works reasonably fast , at least in terms of update rate of display,  but for some reason image is rotated 90 degrees, from landscape to portret orientation. Is there any logic behind that?    If I try to do nested loop array reordering , it just crawls thanks to .NET, I guess. I did not find any image manipulation functions either on capture or display side.  Camera can make horizontal mirror image but not flip on its side.
Any suggestions would be appreciated.
Here is the code sample, I removed saving image to bmp file and reading from it
  'Grab Image that is to be displayed to the Image Viewer
                    ethernetSession.Grab(image, True)
                    Dim pxl As PixelValue2D = image.ImageToArray()
 'Refresh display buffer
                    VIDEO.Images.Item(1).ArrayToImage(pxl.U8)
(3,454 Views)
there was similar discussion in other section and it looks like still unresolved.
Machine Vision -> Vision 2009 ArrayToImage Method difference
(3,445 Views)
