plotting values and getting a "minimum" error message
    Below is the call I make within my C# application plotting the X and Y axis to a scatter graph.
// Push the two dimensional array which contains all the Y Data for each trace
gph.PlotXYAppendMultiple( oPlot.Data, dblData );
dblData value
{Dimensions:[1, 3]}
    [0, 0]: 144.456
    [0, 1]: 144.456
    [0, 2]: 144.45600000000002
oPlot.Data
{Dimensions:[3]}
    [0]: 1.2
    [1]: 2.3
    [2]: 3.4
When this call is made I receive an "Argument Exception" with the message "minimum"  As per the Argument Exception
the gph.Plots[0].ProcessSpecialValues does = true and the x and y data does not contain special values at the same index.
Now,
If I were to change the dblData[ 0 , 2 ] = 144.45600000000005    I would not get the ArgumentException.
Does this have something to do with the size of the double dabbling in the territory of how big a double can be?
Thanks for any advice,
matt
The Only Easy Day Was Yesterday.
(3,827 Views)
Hi Toedwy,
Can you post a small example that demonstrates the behavior?
Best Regards,
Jonathan N.
(3,819 Views)
Hi Jonathan,
My initial post contains the information that demonstrates the behavior.
This line of code....                   gph.PlotXYAppendMultiple( oPlot.Data, dblData );  is basically appending the passed arguments data to a scatter graph.  The values of these passed arguments (oPlot.Data and dblData) were defined above.  Take a look at the dblData arguments last item (this happens to be the Y value).  It contains a 14 significant digit value. [0, 2]: 144.45600000000002.  Oddly, this throws an ArgumentException.  However, when I changed this item's value to dblData[ 0 , 2 ] = 144.45600000000005. I would NOTget the Measurement Studio Argument Exception error "mininum".
What is odd about the error is the terse message!!  And, if I were to change the value's last significant digit from 2 to 5 it appears to work without error.
Let me know if this explaination does not help out.
Matt
(3,814 Views)
Hi Toedwy,
I have tried reproducing the issue but have been unable to so far. Can you please post a Visual Studio solution and project that I can run that demonstrates the behavior. That would honestly be the fastest and quickest way for us to see the problem.
Best Regards,
Jonathan N.
(3,806 Views)
