problem with performing a basic loopback test with NI-6008
I have recently started using DAQmx in C# .NET 4.0 with NI-6008 USB DAQ. I tried out a loopback test by connecting an analog output to an analog input and tried readign the signal sent from the output to input but was not successful in sending the signal ( or maybe a problem with the code). The readign from analog input reads a random value rather than the value entered by user for the output. I connected ao0 and ai3 on the DAQ. here is the code.
private void button1_Click(object sender, EventArgs e)
Task analogOutTask = newTask();
 AOChannel myAOChannel = analogOutTask.AOChannels.CreateVoltageChannel("Dev1/ao0", "myAOChannel", 0, 5, AOVoltageUnits.Volts);
 AnalogSingleChannelWriter writer = newAnalogSingleChannelWriter(analogOutTask.Stream);
 double analogDataOut;
 analogDataOut = Convert.ToDouble(AnalogOut.Text);
 writer.WriteSingleSample(true, analogDataOut);
private void button2_Click(object sender, EventArgs e)
           Task analogInTask = newTask();
           AIChannel myAIChannel = analogInTask.AIChannels.CreateVoltageChannel("Dev1/ai3", "myAIChannel", AITerminalConfiguration.Differential, 0, 5, AIVoltageUnits.Volts);
           AnalogSingleChannelReader reader = newAnalogSingleChannelReader(analogInTask.Stream);
           double analogDataIn = reader.ReadSingleSample();
           AnalogIn.Text = analogDataIn.ToString();
(6,109 Views)
try adding
//Verify the Task
analogInTask.Control(TaskAction.Verify);
//before
//double analogDataIn = reader.ReadSingleSample();
Curt
(6,105 Views)
Code and form view
(6,101 Views)
As seen in the image above, even after adding the code to verify task. Analog input still shows a random value.
(6,100 Views)
Accepted by topic author ranjith_poladi
I built an app using your code (with task.verify) and it worked just fine.
Have you tried different input/output channels?
Curt
(6,098 Views)
Hi Curt,
The problem was with my wiring. I didn't connect the ai3 '-' to the output ground.
I got the right result after doing that.
Thanks for your help.
(6,094 Views)
