problems with asynchronous acquisition and NI-DAQmx
Hi Jonathan,
I have the similar situation .  I want to read sample from the buffer every 1 millisecond. the frequency is 1KHz. I've used the code you mentioned above. And it works except for one problem: I've canceled all calculation part, only reading code left in the callback function.
 Private Sub AnalogInCallback(ByVal ar As IAsyncResult)
                 data = analogInReader.EndReadMultiSample(ar)
                    myTask.Stream.ReadOverwriteMode = ReadOverwriteMode.OverwriteUnreadSamples
                    Dim freshSamples As Integer = myTask.Stream.TotalSamplesAcquiredPerChannel - myTask.Stream.CurrentReadPosition
                    If freshSamples < myTask.Stream.AvailableSamplesPerChannel Then
                        myTask.Stream.ReadRelativeTo = ReadRelativeTo.CurrentReadPosition
                        myTask.Stream.ReadOffset = 0
                    Else
                        myTask.Stream.ReadRelativeTo = ReadRelativeTo.MostRecentSample
                        myTask.Stream.ReadOffset = -myTask.Stream.AvailableSamplesPerChannel
                    End If
                Loop
   analogInReader.BeginReadMultiSample(Convert.ToInt32(samplesPerChannelNumeric.Value), analogCallback, myTask) ' call itself again
 End sub
However even so, the callback function's execution lasts about 5~10 milliseconds which I think  is unnormal.  And this appearently cannot meet my request. How to reduce the execution interval of the callback function?  Any suggestion is  appeaciated. Thanks for attention!
Jeff Zhang
Message 11 of 12
(1,727 Views)
Hi Jonathan,
I think there is a problem in the sub program I poste. Here is the right one:
                    Else
                    End If
 End sub
Thanks!
Jeff Zhang
Message 12 of 12
(1,722 Views)
