"COM object that has been separated from its underlying RCW cannot be used"
I am using Measurement Studio 8.0.1 and VS2005. I used native datasocket library in my VB project.  Threads are used in the applicaiton. There is an exception "COM object that has been separated from its underlying RCW cannot be used" when the form is closing (i.e. at the time the Dispose method is called automatically). Do you know why this would happen? Thx
Best,
Dicky
(16,663 Views)
Error message as below:
System.Runtime.InteropServices.InvalidComObjectException was unhandled
  Message="COM object that has been separated from its underlying RCW cannot be used."
  Source="mscorlib"
  StackTrace:
       at System.Runtime.InteropServices.ComTypes.IConnectionPoint.Unadvise(Int32 dwCookie)
       at NationalInstruments.Net.Internal.a.a(Boolean A_0)
       at NationalInstruments.Net.Internal.a.a()
(16,662 Views)
Can you post a sample project that demonstrates this issue?
Bilal Durrani
NI
(16,653 Views)
Hi Bilal,
I found the problem. I forgot to dispose the datasocket after use. Thanks!
Dicky
(16,643 Views)
Given a Window object "win", make sure to call win.Dispatcher.InvokeShutdown() before calling win.Close(). (This eliminated the error for me. Furthermore, this is ALL I did to fix the problem - I did not modify the Dispose() method at all.)
Message Edited by minister on 09-14-2008 10:11 PM
(12,187 Views)
