samples per channel
Hello:
Problem:
       I'm running sample "ContAcqVoltageSamples_IntClk" for C#.
        It works OK when "Samples for channel <= 100,000.
       When I'm trying to read more then 100,000, for example 100,001
       it's stop responding.
      "Help" explains that for sample rate 10,000 - 1,000,000  NI-DAQ uses buffer 100,000.
       I tried to set
                                  myTask.Stream.Buffer.InputBufferSize = 200000;
      but it didn't work
Q1:  How can i read more then 100,000 samples per channel ?
Q2:  How can i read more then 100,000 sample per channel
        when using two channels  "Dev1/ai0" and  "Dev1/ai1"
Thank you
(3,412 Views)
Please, dismiss my previous message.
(3,406 Views)
Please dismiss my previous message.
Found that 100,000 is the max limit
(3,403 Views)
