saving bitmap using measurement studio
I have a function as follows in C#:
public static void imaq2file(string dir, string file, VisionImage image)
if (!Directory.Exists(dir))
Directory.CreateDirectory(dir);
image.WriteBmpFile(dir + file);
I have tested the rest of my program to see if this function is not the problem. I have used the imagetoClipboard function and tested that actual images are being passed. As far as I can tell only the above function does not work. I even used attrib -r +s drive:\<path>\<foldername> on folder (regedit ->explorer->usesystemsettings->1) to remove the readonly in win 7 from folder. I previously used it for labview's imaq saveimage VI.
Is there a workaround for this (besides using clipboard ->bitmap ->save), or am I using the WriteBmpFile function wrong?
(5,663 Views)
Issue has been resolved this morning, no bug in the actual visionimage.writebmpfile() function. Thanks.
(5,631 Views)
