scattergraph labeling and y-axis assigned issue
Hi, I am using Visual Studio C# to plot multiple sets of y data that corresponds to the same X-axis in my very simple code.
There are 3 curves in my plot, and two of them belongs to the y-axis on the right and the third one belongs to the one on the left.
However, I do not know how to assign the data to the appointed y-axis I want.
Also, I need to show the label for each curve so that the user can know the meaning of each curve. (The Legend I mean)
Can anyone help me with this?
thanks.
The following is the code I have done. (The array dataY, dataZ, and dataW serves as y value, and they all corresponding to the dataX.)
using NationalInstruments;
using NationalInstruments.DAQmx;
using NationalInstruments.Max;
using NationalInstruments.UI;
using NationalInstruments.UI.WindowsForms;
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Threading;
using System.Diagnostics;
using System.IO;
namespace WindowsFormsApplication1
public partial class Form1 : Form
public Form1()
InitializeComponent();
double[] dataX = new double[3];
double[] dataY = new double[3];
double[] dataZ = new double[3];
double[] dataW = new double[3];
ScatterPlot Id = new ScatterPlot();
ScatterPlot Gm = new ScatterPlot();
ScatterPlot Ig = new ScatterPlot();
private void button1_Click(object sender, EventArgs e)
dataX[0] = 1; dataY[0] = 4; dataZ[0] = 9; dataW[0] = 5;
dataX[1] = 2; dataY[1] = 2; dataZ[1] = 11; dataW[1] = 5;
dataX[2] = 3; dataY[2] = 3; dataZ[2] = 7; dataW[2] = 5;
scatterGraph1.Plots.Add(Id); scatterGraph1.Plots.Add(Gm); scatterGraph1.Plots.Add(Ig);
Id.LineColor = Color.Red;
Gm.LineColor = Color.Purple;
Ig.LineColor = Color.Blue;
scatterGraph1.Caption = "VgId plot";
Gm.PlotXY(dataX, dataZ, 0, 3);
Id.PlotXY(dataX, dataY, 0, 3);
Ig.PlotXY(dataX, dataW, 0, 3);
(5,887 Views)
Hi johsieh74326,
I have found a KnowledgeBase article that discusses the issue that seems to be related. I have included it below and I hope it helps!
Assign a Plot to Y-axis: http://digital.ni.com/public.nsf/allkb/669DCC21EC883A0D862565150047B0B4?OpenDocument
Jason D
(5,860 Views)
I didn't see an answer to the portion of the question about identifying plots with a legend.   Did I miss it?
(3,268 Views)
