synchronizing object error
I am having a problem. I am writing a VB .net app that works fine until I try to do a continuous Analog acquisition.  It works fine, I think, but when I try to close the form, I get this error message:  "An unhandled exception of type 'System.ExecutionEngineException' occurred in S3NP code.exe"
Here is the code that I am using.
Try
aireader =
New AITask
reader = New NationalInstruments.DAQmx.AnalogMultiChannelReader(aireader.Stream)
reader.SynchronizingObject = Me
callback =
New AsyncCallback(AddressOf analogInCallback)
running =
True
reader.BeginReadMultiSample(100, callback,
Nothing)
Catch ex As Exception
MessageBox.Show(ex.Message)
'Show the message in a messagebox
running =
False 'set the boolean to false
aireader.Dispose()
End Try
If I comment out the line about the Synchronizing object, I do not get the error, but the code does not work properly either.  According to Microsoft, this error is not supposed to happen.  RIGHT!!!!!
Just for grins, I am using a DAQPad 6016, VB.net 2003 and Measurement studio 8.
Joe White
(3,629 Views)
That was on the machine I wrote the code on.  If I take it to another machine that does not have the IDE on it, I get
Cannot access a disposed object named "NationalInstruments.UI.WindowsForms.NumericEdit".  Object Name: "NationalInstruments.UI.WindowsForms.NumericEdit"
Joe White
(3,625 Views)
Never Mind.  I refreshed the license file and it all went away.  Go figure.
Joe
(3,623 Views)
