trigger Ni scope
I am trying to capture large number of waveform from Ni scope using VC++ .NET. When i trigger the acquisition using the normal mode the acquisition starts immediately. However i want to acqusition to start only after a few millisecs or when there is some activity on the IO line. Requets some suggestions on how this can be done?
(3,734 Views)
Hi Arc,
It sounds like you currently have your application configured for immediate triggering.  In this mode the acquisition begins immediately after being configured by the driver software.  There are a few options that I think may work in your application:
1.  Edge Triggering - occurs when a signal crosses a trigger threshold that you specify. You can specify the slope as either positive (on the rising edge) or negative (on the falling edge) to the trigger.
2.  Digital Triggering - occurs on either a rising edge or falling edge of an external digital signal.
3.  Triggering with Trigger Delay - the amount of time that elapses between when a trigger occurs and when the digitizer actually triggers.
Refer to the High-Speed Digitizer help here for more information about the trigger options available.
Andrew W
Message Edited by TheWoost on 03-16-2007 11:19 AM
(3,723 Views)
