unable to find module dependency with signature - NIMesaDLL
This issue seems unlike other "unable to find module depency" topics in the forum.
I'm using Visual Studio 2010,  Measurement Studio 2010 SP1.  I'm trying to deploy a project built with the setup wizard.  More precisely, I've been deploying it for a few versions now.   It works fine on most computers, but I'm wondering if these warnings are the root of the problem a few users have reported (controls not displaying, timer running very slowly)
This warning appears three times when I build my project:
Unable to find module dependency with signature 'NIMesaDLL.6FE8CEDD_964F_47A2_8F23_5A607953B235'
Scrolling through the list of detected dependencies, I can't find anything matching this signature.  I'm only using UI
controls in my application -- no data acquisition calls, for example.
I get the same warning if I create a blank project (no controls on the form, no code except what Visual Studio creates, but including the NI Windows Forms & User Interface Library as part of the project.   No such warning if I don't include the NI Library.
a) Is it safe to simply ignore the warnings?
b) If not, how can I make them go away?
(2,861 Views)
If you go to C:\Program Files (x86)\Common Files\Merge Modules do you see "NIMesaDLL.msm"? This is the merge module that the UI controls use.
This may also be a good document for you to reference for the dependencies for the UI library:
http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/netmergemodules/
(2,825 Views)
No, I don't see that file.
(2,807 Views)
Does this warning occur on every single computer that you are deploying your project on? Do you have an installer to go along with you build?
(2,792 Views)
