usb-6509 task problem
I have problem with task. This is my code:
I initialize the task.
try
                for (byte i = minRange; i < maxRange; i++)
                    if (pinInit[i]) {
                        digitalOutputWriteTask[i].Dispose();
                    using (digitalOutputWriteTask[i] = new Task())
                        digitalOutputWriteTask[i].DOChannels.CreateChannel(strDevice(i), "", ChannelLineGrouping.OneChannelForEachLine);
                        digitalOutputWriteTask[i].Control(TaskAction.Verify);
                        digitalOutputWriteTask[i].Start();
                        writer[i] = new DigitalSingleChannelWriter(digitalOutputWriteTask[i].Stream); //create writer
                        pinInit[i] = true;
            }catch (Exception ex){
                Console.Out.WriteLine(ex.Message);
                return false;
I have writeDO method in my class:
public bool writeDO(byte pin, bool state) {
            if (pinInit[pin])
                try
writer[pin].WriteSingleSampleMultiLine(true, arrayToSend(1, state));
                        return true;
                catch (Exception e)
                    Console.Out.WriteLine(e.Message);
                    return false;
I have Exception "NationalInstruments.DAQmx.DaqException: Task specified is invalid or does not exist.".
What's the problem??
Thanks in advance
(3,078 Views)
 Hi chino5.
did you already check the device name in MAX? Remember that you need to specify the correct device name to create a new phisical channel. Again, If you want to use a task to acquire or generate signals, the task needs to be created in MAX as well. Task's names in your code must match the ones in MAX.
regards,
Stefano
(3,040 Views)
