vb.net measure battery dc resistance
I am doing a project (newbie) on measuring 3 measurements off a dc battery.
1.  Voltage - Have this one as I adapted one of the samples to do this.
2.  Battery DC Resistance
     (v1 - v2) / (I1 - I2)
3.  Battery AC Impedance
     V1/I2 – V1/I1
We currently have PXI - 8106 chassis with the following cards.
1 pxi 6250
1 pxi 2527
4 pxi 6236
I really want to do this with vb.net
(3,264 Views)
Dear Tartar 813,
It sounds like you probably want to use the DAQmx drivers to build your application. A great way to get you started making API calls to your DAQmx driver is by looking at the examples in the following directory: Program Files>>National Instruments>>NI-DAQ>>Text Based Code Support
(I am assuming you already have the drivers installed.)
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(3,240 Views)
