virtual channels in vb.net
I am trying to call a virtual channel in vb.net.  I have set up the virtual channel using Measurement and Automation Explorer.  I don't understand how to call that channel in my code.   I have been just adding a channel(s) and setting it up in my code but I am trying to use virtual channels.  I have created a channel called "3ChannelHipot".  I tried to call it with mytask = New task("3ChannelHipot") but when I run it I get a message back saying: "Task name specified conflicts with an existing task name."  I have also tried to call it using mytask.AddGlobalChannel("3ChannelHipot") and it does not work either.  I know I am not referencing something right or I have left something out of my code to allow access to the National Instruments virtual channels.  Anyone have any suggestions?  Thanks.
(3,477 Views)
What error do you get when using Task::AddGlobalChannel(String)?
For the error you mention using the Task constructor, I believe that "3ChannelHipot" is a NI-DAQmx Task in Measurement and Automation Explorer and not a virtual global channel.
If you want to load a Measurement and Automation Explorer's task you should use the following:
Dim myTask As Task = DaqSystem.Local.LoadTask("3ChannelHipot")
For adding a channel you already created in Measurement and Automation Explorer, you are using the right method.
Anzurio
(3,463 Views)
