web xydatagraph not refershing
Hi ,
We are using  NationalInstruments.UI.WebForms.ScatterGraph to genenarte a graph.   We are facing problem some times the xaxis range is not refreshing. All the plots are added without any issues but Range is not refreshing.Please refer the attachment.
Version Details:
Runtime Version : v4.0.30319
Version :9.0.40.292
// Before calling  the CreateGraph method we are calling setdaterange method .
//As a default it will show 24hrs interval  after that it will show it in selected date range  which is selected from the top of UI.
   private void SetDateRange(XAxis xAxis)
              try
                 if (isDefault)
                      xAxis.Range = new Range((DateTime)startdate, (DateTime)enddate);
                      xyDataGraph.XAxes[0].MajorDivisions.LabelFormat = new FormatString(FormatStringMode.DateTime, "MM/dd/yyyy HH:mm:ss");
                      xAxis.Mode = AxisMode.Fixed;
                      xAxis.AutoSpacing = false;
                      xAxis.MajorDivisions.Base = (double)DataConverter.Convert(startdate, typeof(double));
                      xAxis.MajorDivisions.Interval = (double)DataConverter.Convert(TimeSpan.FromHours(6), typeof(double));
                      xAxis.MinorDivisions.Interval = (double)DataConverter.Convert(TimeSpan.FromHours(1), typeof(double));
                  else
                                          xyDataGraph.XAxes[0].MajorDivisions.LabelFormat = new FormatString(FormatStringMode.DateTime, "MM/dd/yyyy");
                      if (startdate == enddate)
                          xAxis.Range = new Range((DateTime)startdate, new TimeSpan(23, 0, 0));
                      else
                          xAxis.Range = new Range((DateTime)startdate, (DateTime)enddate.Add(new TimeSpan(23, 0, 0)));
                      xAxis.MajorDivisions.Interval = (double)DataConverter.Convert(TimeSpan.FromHours(2), typeof(double));
              catch (Exception ex)
                  TM.Trace(LogLevel.Error, ex.Message);
// We are adding the graphs as below
 private void CreateGraph(double[] ChartDateTime, double[] Values)  try
  try
                  ScatterPlot newPlot = new ScatterPlot();
                  int chartlen = 0;
                  chartlen = ChartDateTime.Length;
                  double[] dataX = new double[chartlen];
                  double[] dataY = new double[chartlen];
                  DateTime[] dateX = new DateTime[chartlen];
                  XAxis xAxis = xyDataGraph.XAxes[0];
                  YAxis yAxis = xyDataGraph.YAxes[0];
                  newPlot.XAxis = xAxis;
                  newPlot.YAxis = yAxis;
                  yAxis.AutoSpacing = false;
                  yAxis.MajorDivisions.Base = 0;
                  yAxis.MajorDivisions.Interval = 3;
                  yAxis.MinorDivisions.Base = 0;
                  yAxis.MinorDivisions.Interval = 1;
                  yAxis.Range = new Range(0, 10);
                  xyDataGraph.YAxes[0].MajorDivisions.LabelFormat = new FormatString(FormatStringMode.Numeric, "0");
                 newPlot.PlotXY(ChartDateTime, Values);
                  xyDataGraph.Plots.Add(newPlot);
                  xyDataGraph.DataBind();
Please let us know if we have missed out anything. Please find the attached image.
Regards
Guhan.S
Message 1 of 1
(5,199 Views)
