would like the graph to not autoscale after Append when zoomed
Is there a configuration I can set on a ScatterPlot to have the graph NOT autoscale when the graph is zoomed?
thanks
-ed
(3,275 Views)
Hello Ed,
What version of Measurement Studio are you using?  For some graphs there is an option  to select the smart tag (scatter graph for instance) and then select Edit Y-Axis.  From there you can change the mode for how the graph is updated.  This is a newer feature of Measurement Studio so I would check that to see how your graph is being updated.
(3,245 Views)
