03-28-2013 09:07 AM
hello,
I use wpf example in National Instruments\MStudioVS2010\DotNET\Examples\WPF\Standard\Charting\cs
“Charting.2010”,and modifed,
I wonder Why plot becomes slow after a few points(400)!
Thanks!
03-28-2013 02:51 PM
When the graph reaches 400 points in the example project, every additional point added to the chart collection causes the range of the graph to update, which causes WPF to perform a layout pass to re-draw the horizontal scale for the new range. Before reaching 400 points, updates to the chart collection merely resulted in pixels being written to the raster render surface.
The Using the Measurement Studio WPF Controls help topic links to a number of articles on optimizing performance in WPF, including Optimizing the WPF Graphs. For example, setting SuppressScaleLayout on the graph to true, or setting Adjuster on the horizontal axis to PagedChart instead of ContinuousChart, or setting Visibility on the horizontal axis to Collapsed, are all possibilities you can use to achieve improved performance over the default graph settings. The best approach depends on the particular needs of your application.
03-29-2013 09:45 AM
thank you for your help!![]()
