wpf graph export to image
How to export WPF graph to vector or raster image?
Message 1 of 20
(14,911 Views)
You can use a RenderTargetBitmap to convert a WPF visual into a bitmap, and a BitmapEncoder to save an in-memory bitmap image to disk.
Here is an example adapted from How to: Encode a Visual to an Image File that saves a graph to a PNG file:
    // Save control to bitmap.
    Rect bounds = LayoutInformation.GetLayoutSlot( graph );
    var bitmap = new RenderTargetBitmap( (int)bounds.Width, (int)bounds.Height, 96, 96, PixelFormats.Pbgra32 );
    bitmap.Render( graph );
    // Save bitmap to disk.
    string path = ...;
    var encoder = new PngBitmapEncoder { Frames = { BitmapFrame.Create( bitmap ) } };
    using( Stream stream = File.Create( path ) )
        encoder.Save( stream );
~ Paul H
Message 2 of 20
(14,899 Views)
This works indeed, but image quality is low. How can I render high-resolution image from the graph? If I make it very big in XAML, then it's cut in resulting image as it doesn't fit to the screen.
Message 3 of 20
(14,867 Views)
The easiest way I know would be to manually layout the control and wait for it to update before saving it to a bitmap:
    // Force graph to larger display size.
    const int size = 1000;
    Rect bounds = new Rect( 0, 0, size, size );
    graph.Measure( bounds.Size );
    graph.Arrange( bounds );
    // Wait for WPF layout system to update graph.
    Dispatcher.BeginInvoke( new Action( delegate {
        // Save graph to bitmap.
        RenderTargetBitmap rtb = new RenderTargetBitmap( size, size, 96, 96, PixelFormats.Pbgra32 );
        rtb.Render( graph );
        // Return graph to previous size.
        ((UIElement)graph.Parent).InvalidateMeasure( );
        PngBitmapEncoder png = new PngBitmapEncoder { Frames = { BitmapFrame.Create( rtb ) } };
            png.Save( stream );
    } ), DispatcherPriority.Background );
~ Paul H
Message 4 of 20
(14,861 Views)
I even defined this size in XAML. Problem is that when graph is larger than application window, then bitmap is cut (only visible graph part is on image).
Message 5 of 20
(14,846 Views)
Hi EugeneM,
Can you attach a screenshot of the entire application window? I'm not sure what I'm looking at in your screenshot.
Message 6 of 20
(14,822 Views)
this wasn't screenshot but generated png
there is screenshot of application
Message 7 of 20
(14,816 Views)
Hi EugeneM,
Try scaling the image to render at a higher quality. You can use the BitmapCache.RenderAtScale Property to force a higher resolution. See the sample XAML snippet below. Let me know if this gets you headed in the right direction!
<Rectangle>
     <Rectangle.Fill>
          <VisualBrush x:Name="visual1" Visual="{Binding ElementName=graph1}"/>
     </Rectangle.Fill>
     <Rectangle.CacheMode>
          <BitmapCache RenderAtScale="6"/>
     </Rectangle.CacheMode>
</Rectangle>
Alexandra
Message 8 of 20
(14,798 Views)
Accepted by topic author eugenem
If you want to define the size of the control in XAML, then you will need put it in a panel that does not clip the size of its children, like a Canvas:
    <Canvas>
        <Graph x:Name="graph" Width="1000" Height="1000" />
    </Canvas>
Using this XAML with the original bitmap save snippet should produce an unclipped image measuring a thousand pixels on each side.
~ Paul H
Message 9 of 20
(14,773 Views)
Hi, Paul!
Much better indeed. The only problem that PNG from such graph is slightly cut on sides
Message 10 of 20
(14,769 Views)
