yAxis.GetBounds returns empty rectangle?
Using a ScatterGraph, I would like to draw the axis scales in my own code inside the Paint event handler. I can use xAxis.GetBounds() to retreive the rectangle to draw in  for the xAxis but yAxis.GetBounds() always seems to return Rectangle(0,0,0,0). Why?
Adam
(4,914 Views)
Hi Adam,
I haven't been able to reproduce your issue yet.  What language are you using?  Can you post a small snippet of your code that demonstrates how you are trying to access the yAxis bounds?
Marty H.
(4,895 Views)
Thanks Marty.
I'm using C# and VS2005. I wrote a little demo that paints the rectangles returned by .GetBounds(). It shows that when the axis has Position=AxisPosition.Right, GetBounds returns an empty rectangle. I didn't notice that it was just right-hand axes the first time around.
Adam
(4,891 Views)
Not sure that my last post had the attachment.
(4,886 Views)
YAxis contains additional overloads of GetBounds that requires you to specify the YAxisPosition as an argument. By default, GetBounds will return the position of the y-axis as if it were positioned on the left. If you have the YAxis positioned on the right side of the plot area, then you should call yAxis.GetBounds(YAxisPosition.Right).
Abhishek Ghuwalewala | Measurement Studio | National Instruments
(4,883 Views)
Thank you sir. That is correct. Using GetBounds() or GetBounds(YAxisPosition.Left) returns an empty rectangle when the axis is positioned on the right. One must call GetBounds(YAxisPosition.Right) when it is desired to obtain the right hand axis rectangle when position is .Right or .LeftRight.
(4,875 Views)
