zoom / pan without shift / control key?
Hi!
in Measurement Studio 6 CWGraph control (VB6) it was not required to press the shift / control key to zoom / pan. It was rather the interaction mode property, which enabled the desired function.
Is there a possibility to operate the graph 7.1 in the same way?
Andy
(4,607 Views)
hello andy,
as far as i know, there is no possibility to reach the same behaviour of the graph-control.
you must use the modifier key to enable the zoom and panning.
regards,
robert h
national instruments
(4,593 Views)
Hi Robert,
it's a great pity. Do you know whether there's something planned for future versions?
Andreas
(4,568 Views)
We are adding support for this in the future version of Measurement Studio. If you would like to help test the new version of Measurement Studio, you can sign up for the Measurement Studio Beta for Visual Studio 2003 at ni.com/beta
On the .NET graph, look for a property called InteractionModeDefault
Bilal Durrani
NI
(4,546 Views)
Thanks, Bilal Durrani. That's good news. Do you know when this version probably will be available?
Andreas
(4,539 Views)
I can't provide timelines at this point, but if you sign up for the beta at ni.com/beta, you will be notified when it is available.
Bilal Durrani
NI
(4,529 Views)
