Measurement Studio for VB6
4350(USB) VB Example does not work..
Device: NI-4350 USB
Language: VB 6.0
In MAX and LabVIEW6.i I checked it works, but VB samples which included in 4350 CD does not work.
I tried it at diffrent PC, but always i got same result.
The error code is 1309..
Do you have any idea?
(3,436 Views)
The first thing to check when using the 43xx modules with Visual Basic is that you have the proper support installed from NI-DAQ.
It is not quite intuitive, but for Visual Basic support, you also need to make sure the CVI MSVC support is installed from your NI-DAQ driver. This is because the NI-435x driver uses this library.
If you have already installed NI-DAQ, select the NI-DAQ Setup from Start >> Programs >> National Instruments DAQ to install LabWindows/CVI support.
(3,436 Views)
