Measurement Studio for VB6
6536 acquire continuous with trigger -> need faster solution
I use a PCIe-6536 card to control a image sensor with ansi C, Microsoft Visual Studio and DAQmx 8.3 . Im able to generate the requiered signals and the sensor send also data back. To acquire data I have to trigger at one control signal, which starts one measure each 240us.
I tried to aquire the data like this:
    DAQmxErrChk( DAQmxCreateTask("read",&taskREAD));
    //create channel with 4 lines(port 2 lines 0,1,2,3)
    DAQmxErrChk( DAQmxCreateDIChan(taskREAD,DEV1/port2/line0:3,"", DAQmx_Val_ChanForAllLines));
    //set sample clock for reading 20MHz ( 2000 samples)
    DAQmxErrChk( DAQmxCfgSampClkTiming (taskREAD, "OnBoardClock", 20000000, DAQmx_Val_Rising , DAQmx_Val_FiniteSamps, 2000));
    //set trigger
    DAQmxErrChk( DAQmxCfgDigEdgeStartTrig (taskREAD, "/DEV1/PFI0", DAQmx_Val_Falling ));
    while(1)
        //start reading
        DAQmxErrChk( DAQmxReadDigitalU8 (taskREAD,2000,timeout, DAQmx_Val_GroupByChannel,inBufffer,2000, &read,NULL));
        //wait until buffer is full
        DAQmxErrChk( DAQmxWaitUntilTaskDone (taskREAD, timeout))
       //process and save data
Actually everything works, but the problem is, to read once it needs about 2ms.  But I want to use the sensor at maximal rate, it means 10 time faster.
Any ideas to solve this problem?
marc
Message Edited by stehsegler on 11-06-2007 05:34 AM
(9,131 Views)
Please move this thread to Hardware/Digital IO forum
thx
(9,120 Views)
Hello Marc,
as due the specs of the card, it should be able to do this, but I think that windows is not able to do this.
Try to give your application a "high" or "realtime" priority. But attention: if you choose realtime, windows dont react anymore, just your program.
If the timing is than better its clear that windows is the problem.
whitch data you want to read? are the 4 lines with singel data or parallel data?
best regards,
Stefan
(9,092 Views)
Marc,
Just a couple quick comments.  The 6536 and 37 don't support hardware retriggering so your response time will be limited by the processing speed of your system.  I am not sure how flexible your application is but the hardware does support a Pause trigger which allows you to stall the acquisition based on a level trigger.  It may be possible for you to use this to use a single acquisition but pause between your bursts.
Also, the HSDIO supported devices such as the 654x/5x/6x support multi-record acquisition which gives you hardware timed "retriggering".  Information on these devices can be found at:
http://www.ni.com/highspeeddigitalio/
(9,088 Views)
Hello Stefan and Ryan
Thank you both for the answers.
So the problem is that my system (PC) need this 2ms to recognise the trigger event and to react at this.
The Pause trigger punctuate reading data, right. Is it possible to detect when the task is paused? If it isnt possible, then Im not able to process data during aquiring and the best way to be faster is like this:
- increase the in buffer and use pause trigger
- after x burst stop aquiring
- process/save data
- aquire agian.
In this way, the software waste the time not for every burst.
Would that work?
Thank and best regards
Marc
(9,067 Views)
Hi again,
It looks like it works  Smiley Happy
Thanks for the help
have a nice weekend
Marc
(9,058 Views)
Thanks for the update Marc!  Let us know if you bump into anything else.
(9,033 Views)
