Measurement Studio for VB6
Acquiring scaled values NI-DAQmx VB
I'm trying to find out how to get the scaled data values using VB.
DAQmxReadAnalogScalarF64 appears to only work for a single channel value.
What I want to do is use my task, created in MAX, which holds 121 channels and get the scaled values for each channel.
Any clues ?
TIA
(7,172 Views)
   The DAQmx ReadAnalogScalarF64 will only read a single value as it only contains the read floating point 64 bit parameter. This means that the function can only read and store one value at a time.
     The function you will need to use to read multiple samples is
DAQmxReadAnalogF64. This contains the floating point read array parameter to allow you to read multiple samples and store them in an array.
Let me know how you get on with this.
LeeM
NIUK
(7,152 Views)
Thanks for that.
I'm now using the correct function call but data retrieval is very slow - taking 0.45 seconds to get the data for a task holding 121 channels.
Here's my code, any ideas?
Private Sub tmrSample_Timer()
    Dim sampsPerChanRead As Long
    Dim numBytesPerSample As Long
    Dim arraySizeInBytes As Long
    Dim i As Integer
    On Error GoTo ErrorHandler
    If Not taskIsRunning Then
        Exit Sub
    End If
    NumSamps = NumSamps + 1
    DAQmxErrChk DAQmxReadAnalogF64(taskHandleAI, numSampsPerChannel, 10#, _
                    fillMode, data(0), arraySizeInSamps, sampsPerChanRead, ByVal 0&)
    DAQmxErrChk DAQmxReadDigitalLines(taskHandleDI, 1, 10#, _
        DAQmx_Val_GroupByChannel, arrayDI(0), numDI, _
        sampsPerChanRead, numBytesPerSample, ByVal 0&)
    'Populate the listView
    PopulateListView numChannels, fillMode, sampsPerChanRead
    For i = 1 To lvDI.ListItems.count
        If i < UBound(arrayDI) Then
            lvDI.ListItems(i).SubItems(1) = IIf(arrayDI(i) <> 0, "ON", "OFF")
        End If
    lblPerformance.Caption = perf.ElapsedTime
Exit Sub
ErrorHandler:
    tmrSample.Enabled = False
    acquiringLabel.Visible = False
    startCommandButton.Enabled = False
    StopCommandButton.Enabled = False
    MsgBox "Error: " & Err.Number & " " & Err.Description, , "Error"
End Sub
Snelly
(7,119 Views)
