Measurement Studio for VB6
ActiveX control, cwimaq.ocx, LoadInterfaceDefaults method fails with IMAQ 1394 driver.
I'm trying to run your VB sample using the ActiveX control and your 1394 IMAQ driver. I can't read the interface defaults for the camera. The LoadInterfaceDefaults method returns with a 30222 error, Newer version of NI-IMAQ required. I downloaded the 6.0.4 version and it seemed to install correctly. It doesn't fix the problem and when I look at the version using Windows explorer, it show the version as 6.0.3.563.
(3,964 Views)
There are two different NI-IMAQ drivers: one for the IEEE-1394 interface, and one for the PXI/PXI frame grabbers. LoadInterfaceDefaults is an NI-IMAQ command and is not supported by the NI-IMAQ 1394 driver. The method is looking for a valid version of NI-IMAQ (2.x), which will not work with 1394 cameras.
The 6.0.4 version is actually your version of NI Vision, which is the image processing toolkit for IMAQ.
(3,964 Views)
O.K. That was 10/5/2001. Has NI fixed this problem yet?
(3,964 Views)
