Measurement Studio for VB6
After installation on a replace
ment PC I keep getting an annoying pop up telling with "cwui" in the caption telling me that a newer version is available. I have over 50 CW objects embedded in the application. This Pop up interrupts me once for each object. Why do I have to upgrade???The original development PC lost its hard drive and power supply so it had to be replaced. I installed the VB development environment and installed the Component works CD. Now this annoying pop up occurs when compiling the VB code and when the application is executed.
(3,080 Views)
ment PC I keep getting an annoying pop up telling with "cwui" in the caption telling me that a newer version is available. I have over 50 CW objects embedded in the application. This Pop up interrupts me once for each object. Why do I have to upgrade???Hello,
Our controls do not detect or report any newer versions since you can only register one version at once on a given system.
One thing that could be causing this, is the fact that when you reinstalled the ComponentWorks CD due to some system failure, it might have caused your existing VB programs to "lose" some licensing information; a fix would be for you to redrop the controls onto the form. But with the info you gave us, it's hard to diagnose the real problem. If this does not solve the problem, please attach an image of the message.
Mika Fukuchi
(3,080 Views)
