OK, here's an quick example. Create a new Windows Forms application and add a ScatterGraph and a Label to the form. Add a cursor to the ScatterGraph, then add the code below to the form. This generates 50 random data points when the form is loaded and plots them, then uses the cursor's AfterMove event to display the current X and Y positions in the label. Here's the code:
Private Sub OnFormLoad(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Const dataLength As Integer = 50
Dim xData(dataLength - 1) As Double
Dim yData(dataLength - 1) As Double
Dim rnd As Random = New Random
For i As Integer = 0 To dataLength - 1
xData(i) = i
yData(i) = rnd.NextDouble() * 10
ScatterGraph1.PlotXY(xData, yData)
End Sub
Private Sub OnAfterMoveXYCursor(ByVal sender As Object, ByVal e As NationalInstruments.UI.AfterMoveXYCursorEventArgs) Handles XyCursor1.AfterMove
Label1.Text = String.Format("({0}, {1})", e.XPosition, e.YPosition)
End Sub
Hope this helps.
- Elton
