Measurement Studio for VB6
Anyone has experience in using MS Visual Basic 6.0 to call NI-6601 Timer/Counter functions?
I need your help.
Thank you;
(3,520 Views)
The NI-DAQ driver ships with Visual Basic examples using NI-DAQ function calls and using ActiveX controls.
While installing NI-DAQ choose to do a custom install and select support for Visual Basic. If you already have NI-DAQ (6.8 or higher) installed you can run the NI-DAQ installer again (setup.exe) and choose to install NI-DAQ. Then choose Add/Remove and from the list you can choose to install support for Visual Basic.
Examples for use with the 6601 can be found in the Counter folder.
(3,520 Views)
Thank you Michael:
I installed the 6601 software and hardware.
I have tried couple examples written in VB.
All examples, I got the same error message at this statement:
CWCounter1.Configure
Please instruct how do I do?
Thank you;
Adam
(3,520 Views)
