Measurement Studio for VB6
Base Time Unit for Axes Format on CNiGraph
I am graphing many points of data over a time of several days long. I was wondering if there is a way to format the Axes on the Graph to display a base unit of hours instead of days. It is a simple enough task to convert between days and hours, but I find that once the graph reaches the 24th hour it starts displaying time from 0. If I use Integers than the time is displayed like so, (26.75) instead of the preferred display(26:45). I could write a function to convert from decimal format to time format, but I'm not sure how to use this function when setting the format string.
Any help would be greatly appreciated.
(5,858 Views)
If you look up the FormatString Property for CWAxis in the Measurement Studio Reference, the last paragraph before “Example” is
“With ActiveX controls, the date is implemented as a floating-point value, measuring days from midnight, 30 December 1899. So, midnight, 31 December 1899, is represented by 1.0. Similarly, 6 AM, 1 January 1900, is represented by 2.25, and midnight, 29 December 1899, is -1.0. However, 6 AM, 29 December 1899, is -1.25. To interpret the time portion, take the absolute value of the fractional part of the number. Thus, 1 second equals 1 / 24 hours / 60 minutes / 60 seconds, which is 1/86400 or approximately 1.157407e-5.”
The point is that as soon as the fractional part of your value goes from about .9999942 to about .9999943 your time will roll from 23:59:59 to 00:00:00, if you are using one of the Date or Time format strings. If you want to stick with a Date or Time format string, “mm/dd/yy hh:nn:ss” might suit your needs best.
Or, you could try using a function like you suggested and display the converted time as a number. That is, once you turn 26.75 into 26.45, display 26.45 as a Number.
I hope this helps.
Eric M
(5,842 Views)
