Measurement Studio for VB6
Beginning with Measurement Studio
I'm a VB6, VB.Net, C# developper
I'm also using LabVIEW at work (I'm teacher)
I'd like to mix these 2 knowledges but I first need to know what I should read
to begin with Measurement Studio
Is there some tutorials available (without Measurement Studio) because I first need to learn
before using something (or planning to buy it)...
Kind regards
(7,995 Views)
In fact I found a user manual at
http://sine.ni.com/manuals/main/p/sn/n23:4.30
I also found a Class Hierarchy but where canI found more information
(methods of class for example)
(7,994 Views)
If you want to learn about Measurement Studio before buying it, I recommend you go to http://www.ni.com/mstudio/try/.
This page has videos, demos you can use without installing Measurement Studio, and an online evaluation tool that allows you to use MStudio for three hours (also without installing it).
You can also feel to post questions here and we'll be happy to answer them.
David Rohacek
(7,976 Views)
Thanks for the link (even I ever found it before)
I'm looking for a document explaining every Class and Method of NI Measurement Studio
(7,964 Views)
Outside of the help documentation that is a part of Measurement Studio, we do not have the kind of detailed information that you are requesting.  You can download an evaluation copy of Measurement Studio which will give you access to the help documentation for the entire API. One caveat to this is that you will need a viewer to view the .hxs files that make up the help documentation.  If you have access to Visual Studio, this should not be a problem.
If this is not suitable, do I have your permission to get your email address so that I can contact you offline regarding other possible solutions?
Thanks!
NickB
(7,938 Views)
Thanks for the idea but the problem with installing evaluation version is that I will have to install Measurement Studio Eval and loose some days of evaluation period just for reading the help ! If you can send me offline the help at my email adress (s dot celles at gmail dot com) I'd be interessted
Kind regards
(7,931 Views)
