Measurement Studio for VB6
Bug using CWGraph-Axis-FormatString combined with comma as desimal symbol?
This works: I use a decimal point (.) as decimal symbol on my Win2000 PC. Setting CWGraph-Axis-FormatString = "*.01" changes e.g. 12 to 0.12.
This doesn't work: I use a comma (,) as decimal symbol on my Win2000 PC. Setting CWGraph-Axis-FormatString = "*.01" or = "*,01" both changes e.g. 12 to 0.
How can I scale my axis when I use a comma (,) as decimal symbol?
(3,359 Views)
How are you specifying that a comma is the decimal symbol? Through the "Decimal symbol" field of the Numbers tab in the Regional Options in Control Panel?
- Elton
(3,359 Views)
Yes, Elton. In Regional Options, I've specified comma as decimal symbol both in the "Decimal Symbol" field of the Numbers tab and the "Decimal Symbol" field of the Currency tab. In addition, the "Digit grouping symbol" field in the numbers tab contains a space (all these settings are default if you choose "Norwegian (Bokmal)" as locale). After these changes I even restarted the PC, but the scaling still didn't work.
Any ideas?
(3,359 Views)
