Measurement Studio for VB6
CW3DGraph in Delphi
I have this simple code (delphi):
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs,
  OleCtrls, CW3DGraphLib_TLB, StdCtrls, Math, GeneralDAQEventLib_TLB;
type
  TForm1 = class(TForm)
    CWGraph3D1: TCWGraph3D;
    Button1: TButton;
    Button2: TButton;
    GeneralDAQEvent1: TGeneralDAQEvent;
    procedure FormCreate(Sender: TObject);
    procedure Button1Click(Sender: TObject);
    procedure Button2Click(Sender: TObject);
  private
    { Private declarations }
  public
    { Public declarations }
  end;
var
  Form1: TForm1;
implementation
{$R *.DFM}
procedure TForm1.Button2Click(Sender: TObject);
var
i,j:integer;
data:array[0..20,0..20] of Duoble;
begin
  For i:= 0 To 20 do
        For j:= 0 To 20 do
            data[i, j]:= Sin(i * 0.314);
    CWGraph3D1.Plot3DSimpleSurface(data);
    CWGraph3D1.Plots(1).Style := cwSurface;
    CWGraph3D1.Plots(1).ColorMapStyle := cwShaded;
end;
end.
When I compiler I get this message:
"[Error] Unit1.pas(60): There is no overloaded version of 'Plot3DSimpleSurface' that can be called with these arguments"
What happen????
ZGut
(7,213 Views)
Hey ZGut,
We at National Instruments don't really support our Component Works ActiveX controls in Delphi, and they have not been tested.  I will, however, point out one thing that might be a problem just looking at the code.
It seems that there is no prototype for the Plot3DSimpleSurface function defined with the specified parameter types.  In Visual C++, the prototype for this function has one parameter that is defined as a CNiMatrix, which is a custom data type that we define in C++.  The translation for a CNiMatrix probably at a lower level is simply a 2-D array of doubles, as it appears you assumed.  The problem that I notice, however, with your code is that you have a 2-D array of Duoble defined rather than double, which may cause a problem.  I'm not sure how Delphi data types are defined, but looks like it would be a different kind of data type.
Beyond this advice, maybe one of our users has some advice for using our ActiveX controls in Delphi.
Andy McRorie
NI R&D
(7,199 Views)
HI
I am solving this problem.
var
i,j:integer;
data:array of Variant;
begin
data:=VarArrayCreate([0,20,0,20],varVariant);
  For i:= 0 To 20 do
        For j:= 0 To 20 do
end;
end.
Now, it works.
Regards
zgut
(7,189 Views)
