I'm using an array of CWGraphs for process monitoring. I have set up bindings on each graph to data
files on our local network. I would like to use the CWBindingDataUpdated event to check to status of
the data, but there is a conflict between the 'Index' parameters that are declared, one for the graph array, the other for the binding.
Is there another way to monitor the data update event?
Curt
