Measurement Studio for VB6
CWDIO - group 2 ports
I posted this on the DIO board, but didn't get a response.
I'm using VB and CW 6.0 with a PCI-96 dio card.
How do I set 2 8 bit ports to work as 1 16 bit output?
Curt
(3,266 Views)
Curt
When specifying the channel string either in the DO ActiveX control or through the .ChannelString property, just select both ports. For example, to group ports 0 and 1 together, type in 0,1.
Let me know if this is not working for you.
Brian
(3,266 Views)
I'm using the DIO object. I just want to send a
16 bit word value to a port, not generate a waveform.
I've have tried to use the channelstring property.
I also tried using the Named Channels using the
Data Neighborhood in NI-Max, but neither lets me
group 2 ports together.
I checked the user manual but I couldn't find any info
stating I could or couldn't group 2 ports on the DIO-96
Any help would be appreciated.
Curt
(3,266 Views)
